Always On Internet Monitoring
Enterprise & organization hardware agents
Our hardware agents can monitor your wired connection or your WiFi, 4G, 5G, LTE Internet service while saving power and running 24/7. These are self-updating for the best possible reports.
Mix software and hardware agents as needed
Use our Internet monitor software or take advantage of our optional hardware agents. These are a one-time cost, self updating, and operate 24/7 using less than one amp of power. Monitoring is consistent and non-stop unlike a PC or server that may be rebooted or turned off accidentally.
Monitor remote locations like customer premises, remote equipment rooms / cabinets and much more. Use our 100Mbps when you do not want to constantly saturate your connection and only want to know if you have usable bandwidth or use our 2.5Gbps agent when you need to know what the maximum Internet speed is at all times.
100 Mbps Hardware Agent
These devices offer a 1Gbps wired interface, 2.5Ghz wireless radios, and single Access point.
2.5 Gbps Hardware Agent
These devices offer a 2.5Gbps wired interface, 2.5Ghz, 5Ghz wireless radios, and dual Access points.
Connect a camera
Our agents allow a compatible (UVC) webcam to be connected.
Access credentials, resolution and other settings are provided in the camera settings page and a convenient access link is placed in the dashboard.
Private DNS server
Our agents come with a DNS server built in. Use it for redundancy or for DNS privacy. In light of net neutrality being in question, there’s no way to know who is monitoring the locations you are visiting on the Internet.
Now you can avoid provider DNS and large well known publicly available DNS services profiling your every move when ever you want.
WiFi/LTE/4G/5G monitoring
Our agents can be used to monitor wired or wireless Internet services such as LTE 4G/5G.
Enabling wireless monitoring is as simple as entering a few fields in the wireless section of the dashboard and the network will automatically switch to wireless or wired.
Special options that work with select hardware agents
Environment Sensors with alerts
Environment enabled hardware agents can be ordered which can run all of the Internet monitoring features above plus environment monitoring simultaneously.
The sensor monitors temperature, humidity, light, barometric pressure, sound, air quality, vibration and even seismic activity at the location it is installed at. Each metric can be set to alert someone if an upper or a lower threshold has been reached.
For example, if temperatures go below or higher than a set range or if humidity becomes too high, alerts can be sent. Notifications can be via email, dashboard and optionally SMS.
Sensor enabled agents come with one year of monitoring and sensor metrics included and can be ordered here for $205.00.
Learn more about our combined environment and Internet monitoring solution here.
Remote Access Service (RAS)
Secure, encrypted access to remote networks, hardware cabinets, field sensing equipment, security systems, practically anything can be reached without opening firewall ports. If nothing is interesting for hackers to see, they will move on to another potential target.
RAS is the perfect way to give admins direct access to configuration screens, firewalls, even desktops (RDP) at remote customer networks, unmanned equipment rooms, cabinets and countless other situations. No software to install, everything needed is built into our tiny hardware agent.
RAS is not for heavy data traffic such as transferring files or high bandwidth usage. RAS can be enabled on most of our hardware agents through the dashboard
Works with our 100Mbps agents. Learn more about our Remote Access Service (RAS)
Business And Home
Broadband initiatives, hotel and other chains, remote employees, remote sensing/equipment. Easy deployment anywhere, any time and situation where IP connectivity is involved.
MSP, ITSM, Tech Support
You cannot afford complaints. Reliable services are a must. Preempt problems, save time and money by confirming or eliminating Internet related events.
Instant Notifications
Quickly learning about Internet connectivity, low bandwidth issues and potential security risks are especially important for critically connected remote locations, hardware and services.
