Home and small business
Stumped by technology quirks and challenges? Check out our “Good Question” blog or send us a question of your own for us to solve.
Introducing ISP Tracker Answers
You no longer have to dig through charts and measurements to understand your monitored results—simply ask a question. ISP Tracker Answers checks your agent’s recorded data and explains what it finds in plain language.
SSH Not Working? Fix Remote Access (Starlink, LTE, CGNAT)
Access your home server over SSH from anywhere Even when your internet provider blocks remote access. If SSH suddenly stopped working, even though nothing changed, this is likely why. If you’ve tried to SSH into your home network on Starlink or similar providers, you’ve probably seen: Connection timeouts Ports that won’t open Everything configured correctly, but nothing connects You check your...
Your ISP Won’t Let You Access Your Home Network?
Locked Out Of Your Own Home Network? Bypass their blocking. Here’s The Fix Access your cameras, NAS, servers, and other devices from anywhere, even when your internet provider blocks normal remote access. This works for everything from cameras and web dashboards to full access like SSH. For years, remote access was simple. You set up port forwarding in your router and connected to your devices...
Monitor Web, Online Services From Inside and Out with Alerts
Monitor websites and online services from both sides of the connection. ISP Tracker provides website and online service uptime monitoring from the Internet, while also monitoring the connection and hosting environment from inside when an agent is installed on the server. This helps answer a more useful question than simply “Is the website up?” — is the service itself unavailable, is there a...
Monitor Your Internet With Raspberry Pi 3A, 3B+, 4, NanoPi, And Other ARM Devices
Automate ISP Tracker Internet monitoring on Linux This article has been updated to describe our latest method of installing ISP Tracker on your desktop or server. In the previous method, you could have to manually complete a number of steps but now it's easier than ever. The new method involves downloading two files, putting them in the correct directories then running a few commands. Note that...
Monitor Your Internet With Ubuntu Desktop Or Server
Monitor Your Internet With Linux Desktop Or Server
Fix Constantly Changing MAC Addresses Using eMMC
Constantly changing MAC addresses can be quite frustrating. The following two solutions are what we use when working with eMMC based devices such as the NanoPi R5C that we modify for ISP Tracker. Method number one The code will try to discover the path and name of the eMMC device and if it cannot auto discover it, it will prompt you for the device name. In the case of the R5C NanoPi, the path is...
The Internet is down and it’s not my fault
ISP Tracker eliminates hours of frustrating calls to providers support line, gives consumers and IT support proof of what is happening with services during and after problems. PRESCOTT, AZ – How many times can you reboot a router before you give up in frustration? That's the question Mike Paradis, ISP Tracker creator, asked himself a few years ago. Despite paying for an expensive business...
Securely access remote LAN devices without opening inbound firewall ports Reach the devices at a remote location without exposing them through port forwarding ISP Tracker Remote Access Service provides encrypted remote access through any ISP Tracker hardware agent. It can be enabled from the ISP Tracker dashboard, so no separate remote-access appliance is required. An inexpensive RAS data...
An Alternative To Monitor.io, Monitor-io.com
NOTICE: The Monitor-io device is no longer supported due to a lack of demand. For the previous monitor.io, aka monitor-io.com, customers At ISP Tracker, we understand that change can be both intriguing and daunting, and that's why we created this short article to address questions that come in from previous monitor-io customers now and then. The two main questions are Is the...
Sound of Silence: Dropped VoIP calls lose customers
Sound of silence: Dropped VoIP calls lose customers. VoIP and online service providers solve service issues and retain customers with ISP Tracker service. PRESCOTT, AZ – When Internet issues arise, especially Voice-over-IP (VoIP) and network related issues, customers can be quick to assign blame before considering that the problem is more likely with their own connectivity. VoIP and online...
Do You Offer VoIP, IT Support, Content Services?
When Internet issues arise, especially VoIP related, customers using your services can quickly point the finger at you. You need a speedy way of determining if the problems are at the customer premises or with their Internet connection. By knowing where the problems are and taking care of them quickly, your customer will always trust that you are on top of things as you should be. Find problems...
Eliminate Most Panicked Customer Support Calls
In the IT/ISP industry, we sometimes experience customers quickly pointing the finger toward their support company if they lose Internet access and therefore, VoIP, browsing and other services. The majority of short lived problems are often Internet related and need to be assessed quickly in order to keep customer confidence. If your business handles customer premise managed services such as...
Is Your Internet Provider Ripping You Off?
It frustrates me that I keep coming across people who are not at all aware of how their Internet provider is ripping them off. I don't blame them for their lack of technical knowledge but I definitely blame the Internet service industry that preys on their customers. In this case, we're talking about SparkLight in Arizona. To explain my accusation, here is a short story of how I helped a friend...
AI Referrals vs Traditional Search Engines
As Artificial Intelligence (AI) continues to advance, it has the potential to significantly impact the visibility and ranking of websites in search results. With the ability to provide highly personalized and relevant results based on user data, AI is changing the game of online search. But what does this mean for new online services and websites that are not well known or able to invest in...
My employer wants proof of Internet problems
If your employer is getting upset with you due to internet outages, it is important to find a way to prove that the service you are using is suffering from problems. One way to do this is by using ISP Tracker to automatically track internet outages and service disruptions by your ISP. By using ISP Tracker, you can gather facts and proof of internet outages to show your employer that the problems...
Why should I monitor my Internet connection?
There are several reasons why you might want to monitor your Internet connection. At the end of this article, we'll even give you a fully automated way of monitoring your Internet and provider. To troubleshoot connectivity issues If you are experiencing connectivity issues, monitoring your Internet connection can help you identify the root cause of the problem. For example, if you notice that...
Community Internet monitoring and consulting for free
Is your area suffering unreliable Internet services? As a community service and at no cost, ISP Tracker can help your community get more reliable Internet services. The most challenging aspect of ongoing Internet problems is trying to gather enough facts, proof, and collaborative data when the provider won't fix or doesn't see the problems. Individual complaints can be dismissed but a...
Monitor Internet connectivity and environmental conditions
Environmental monitoring Monitor the connection and the conditions around it ISP Tracker environmental monitoring combines continuous Internet connection monitoring with temperature and humidity information from the monitored location. This is especially useful at remote or unattended sites where nobody may be present to notice changing conditions until equipment or connectivity begins having...
Internet Of Things Data In Your ISP Tracker Dashboard
Add your own data in your ISP Tracker dashboard When developing software applications using Internet of things (IoT) devices like mini routers, raspberry pi and other development boards, having the ability to view outputs or send control commands and signals back to remote devices are critical aspects of overall functionality. Sure, using the term Internet of things might sound dated to some but...
Keeping the Internet healthy during COVID-19
It's Summer 2020 and with everything that is going on with COVID-19, reliable Internet access is critical. Internet and other service technicians are just as stressed about walking into customers' homes or offices as their customers are about being visited. With more employees working from home, work loads for technicians in the field will certainly increase. Whether working from home or self...
