NOTICE: The Monitor-io device is no longer supported due to a lack of demand.
For the previous monitor.io, aka monitor-io.com, customers
At ISP Tracker, we understand that change can be both intriguing and daunting, and that’s why we created this short article to address questions that come in from previous monitor-io customers now and then.
The two main questions are
Is the service identical: No, but you’ll find ISP Tracker just as useful for monitoring your Internet service and provider. Note that unlike monitor-io, hardware is optional, used if you would prefer not keeping a PC on or need constant monitoring.
Check out our demo to get some idea of what to expect.
Can my monitor-io hardware be used?: Yes, you’ll be able to use your old monitor-io hardware CAN be used with ISP Tracker. Read on to learn more.
Let’s talk about the above answers with some additional details.
No hardware is needed to get started
Unlike the monitor-io service, no hardware is actually required to get started. Simply download, install, and start monitoring – it’s that easy. We support Windows, Linux, ARM, AR71xx, and RAMIPS devices.
ISP Tracker hardware is optional
If you don’t want to keep a PC on for continuous monitoring, our hardware agent is your answer. It’s a compact device that houses our powerful software, ensuring uninterrupted service without any hassles. It uses less than one watt of power, never misses a problem, is self-updating,
Note that many additional functions come with our hardware agent such as connecting a camera, gaining a private DNS server, being able to go from wired to wireless monitoring and even enabling an access point if you need one to connect wireless devices to.
Internet accessible dashboard
While not the same as the one you might have been used to, it’s easy to use and understand. Our forums are always there to help you too.
Your dashboard shows a heartbeat, a breakdown of Internet problems, outages with details, average times of outages, and a map showing others in your area experiencing problems if they are also using ISP Tracker. Optionally enable automated speed testing, flexible alerts, and more.
Outages include a lot of important information, when it happened, how long it lasted, who the problem was with, what hop went down, who owns the hop. This is useful for those who want more details.
Access your dashboard over the Internet, using a mobile or other location if the monitored location is currently down.
Can I use my existing monitor-io hardware?
Because your hardware is ARM based, our monitoring agent will run on your device. Note however that at the moment, the display will no longer work as you are used to. However, you can optionally enable email alerts to know when your Internet is down even if you aren’t at that location. And of course, all logged events will be in your ISP Tracker dashboard.
An image for your old monitor-io device is available at only $20.00 and by request only at this time.
First, create an account on app.isptracker.com then send an email to the following address.
IIn turn, we will send you a paypal invoice, once paid, we will create the image for you then send you activation details.
Note that an ISP Tracker subscription is also required.
Please be sure to include a working mail address and at minimum, your first name.
