How ISP Tracker works
ISP Tracker gives you a clearer answer when your Internet is not behaving normally: is the problem on your connection, with your provider, affecting a website, or appearing somewhere wider?
It starts with an agent monitoring from a real location and becomes more useful as results from more locations reveal broader patterns.
From one connection to a clearer picture
Your agent serves you first. It watches your Internet connection over time and gives you information before you spend time rebooting equipment, changing Wi-Fi settings, or calling your provider without evidence.
Install an agent
Run ISP Tracker on a supported Windows or Linux computer, server, ARM device, or dedicated hardware agent.
Monitor continuously
Small background checks follow connection health, interruptions, and other available measurements.
See what changed
Use Local Status for an immediate local view and the private dashboard for history and longer-term patterns.
Compare wider evidence
Public-safe results from participating locations help show when similar conditions may extend beyond one connection.
Immediate answers and useful history
ISP Tracker gives you two complementary views of your monitoring location.
Local Status
Every current agent includes Local Status. From another computer on the same LAN, you can quickly see how the agent and local monitoring are doing without signing into the private dashboard.
Your private dashboard
Sign in to review connection history, recurring interruptions, measurements, and reports over time. This is where a brief problem becomes useful evidence instead of a forgotten guess.
What the agent helps you understand
Your connection
Know when connectivity changes, when an interruption begins, and how long it lasts.
Your provider
See when evidence from your location may point beyond your own equipment and toward the provider path.
Websites and services
Understand whether selected destinations can be reached and whether reachability differs across providers or areas.
Patterns over time
Build history that helps reveal recurring slowdowns, drops, interruptions, and other available measurements.
Why more monitoring locations matter
One agent describes one connection. Several participating locations can reveal whether similar trouble is limited to one place, appearing nearby, related to one provider, or showing across separated areas.
- Nearby agents make ZIP, town, and neighborhood information more useful.
- Different providers help separate destination problems from one provider’s path.
- Separated locations provide stronger evidence of a wider reachability pattern.
- Historical results help show when a pattern began, changed, or cleared.
This comparison powers the public-safe summaries in ISP Tracker Live while keeping the primary benefit focused on each participant’s own connection.
Lightweight monitoring built around privacy
The agent is designed to run quietly and use small, efficient measurements. It is not intended to consume the connection it is monitoring.
Not browsing surveillance
ISP Tracker monitors Internet reliability. It does not need to know what you read, watch, send, or search for to understand connection health.
Private account information
Your detailed dashboard and account data remain separate from the public presentation on ISP Tracker Live.
Public-safe summaries
Public pages use broad locations and plain-English evidence without exposing raw agent IDs, private IPs, private hops, or internal technical details.
Read the full Privacy Statement for more information.
What you need to run an agent
Continuous monitoring runs on a supported Windows or Linux computer, server, ARM device, or dedicated ISP Tracker hardware agent that can stay online often enough to provide useful measurements.
A phone is not the continuous monitoring agent. If you are visiting on mobile, you can create your account now and install the agent later from a supported computer or hardware device.
Free monitoring remains available. If you want to help provider better statistics for your area, please take part. New users can try every Extended Service feature for 90 days when we offer promotion codes on this page. Then continue free or keep Extended Service with no obligation.
Stop guessing about your Internet
Run an ISP Tracker agent for better answers about your own connection. As more locations participate, those answers become more useful for everyone nearby.
