ISP Tracker Pricing
Start monitoring free, add Extended Monitoring when you need more history and investigation, and choose dedicated hardware only for locations that should be monitored independently of a computer.
Use free software agents, optional dedicated hardware, or a combination of both in the same ISP Tracker account.
Start with the monitoring you need
Begin with useful free monitoring, then add more history and investigation only where it helps.
Free Monitoring
Free
See what ISP Tracker observes about the connection and begin building an independent view of its reliability without paying for service or purchasing hardware.
- Start monitoring without a subscription
- Use a compatible Windows or Linux system
- See the current condition of the connection
- Add Extended Monitoring later if more history and investigation are needed
No subscription or hardware purchase is required
Extended Monitoring
$5.95 per agent monthly
Keep more history, receive notifications, and investigate recurring problems with more detailed reporting when a connection needs closer attention.
- Understand performance over time
- Keep evidence of recurring problems
- Receive notifications when problems are detected
- Investigate outages and connection changes in greater detail
Volume discounts apply as you add more monitored locations
Monthly Extended Monitoring pricing
Progressive pricing applies to every ISP Tracker member. Each group of agents is billed at the rate for its tier; moving into another tier does not reprice agents in earlier tiers.
| Agents in tier | Monthly price per agent |
| 1–10 | $5.95 |
| 11–20 | $5.50 |
| 21–30 | $5.00 |
| 31–40 | $4.75 |
| 41–50 | $4.25 |
| 51+ | $4.00 |
For example, the first 10 Extended agents are billed at $5.95 each, while agents 11–20 are billed at $5.50 each.
Software or dedicated hardware
Choose free software agents where a suitable Windows or Linux system is already available. Choose optional dedicated hardware where monitoring should continue independently of a PC or server. Dedicated agents arrive configured and tested, are a one-time purchase, and can be used with free monitoring or Extended Monitoring. Members can use software agents, hardware agents, or both in the same account.
Optional dedicated hardware
Choose the hardware that fits the connection and location. Hardware is optional; it is not required for accurate monitoring.
100Mbps Hardware Agent
A lower-cost choice for continuous visibility into connection availability and normal performance, rather than repeatedly measuring the maximum speed of a very fast connection. It is practical for remote locations, backup connections, metered or cellular connections, and locations where lower bandwidth use matters.
One-time hardware pricing
| Quantity | Price per unit |
| 1–10 | $54.95 |
| 11–49 | $51.50 |
| 50–99 | $49.50 |
| 100+ | Contact us |
An environment monitoring version is also available for locations that need temperature and other conditions monitored with the connection.
Hardware is ordered as needed through the ISP Tracker application.
2.5Gbps Hardware Agent
For faster connections where the monitoring hardware should not become the limiting factor. It provides a 2.5Gbps wired interface and dual-band Wi-Fi, and each agent is configured and tested before shipping.
| 1–10 | $129.00 |
| 11–49 | $124.00 |
| 50–99 | $119.00 |
| 100+ | Contact us |
This option is prepared for connections approaching or exceeding 1Gbps.
Hardware volume pricing is based on the total number of units in an order. The price shown for the applicable quantity range applies to each unit in that order.
Hardware costs may change with supplier pricing and availability. Orders of 100 or more may qualify for additional volume pricing based on current equipment costs.
More visibility as you add locations
After there are 10 active agents, the Overview Map automatically becomes available. View monitored connections together, compare what is happening across locations, and recognize whether a problem is isolated or shared. More locations help build independent evidence when recurring problems need investigation, and additional administrators can help manage different locations. Lower progressive pricing applies as more Extended agents are added.
Start with the option that fits your location
Install a free software agent, add Extended Monitoring when a connection needs closer investigation, or choose dedicated hardware for continuous independent monitoring.
