Using ISP Tracker Live
ISP Tracker Live helps you work out whether an Internet problem may be limited to your connection, related to your provider, affecting a website, or appearing across a wider area.
The information is evidence from public reports and real monitoring locations. It helps you stop guessing, but it should not be treated as proof that a website or provider is down everywhere.
Understanding what ISP Tracker Live is telling you
ISP Tracker combines measurements from participating locations with moderated public reports. The page uses careful terms such as reported, observed, watching, and may indicate because Internet problems can have several causes.
One result is one point of view
A problem seen from one location may be local to that connection, provider, DNS service, or route.
Several areas create a stronger pattern
Similar results from separated locations can indicate something wider, but they do not automatically prove a global outage.
Current status and history are different
A service can be reachable now while its history still shows that a monitored location had trouble earlier.
Coverage affects detail
Areas with more participating agents can provide clearer local comparisons than areas with little monitoring.
The question ISP Tracker helps answer: “Is it only me, or are other people and monitored locations seeing something similar?”
Check a Website
Enter a hostname or domain to ask available ISP Tracker locations whether they can reach it. This checks reachability from those locations; it does not declare whether the website is globally online or offline.
Reachable
The site responded normally from the monitored locations that completed the check.
Not reachable
One or more completed locations could not reach the site. ISP, region, DNS, routing path, or website conditions may differ.
DNS failed or timed out
The location could not resolve the name or did not receive a response in time. That result describes the check location, not the entire Internet.
Still checking or limited results
The check has not finished, or too few locations completed to provide a useful comparison. Allow the check to finish before drawing conclusions.
Check Your ISP and provider reports
Start typing a provider name and select the closest suggestion when one appears. Suggestions help normalize different provider names and aliases. You can also add a ZIP or postal code and a neighborhood or area to look for nearby information.
Search for the provider. A recognized provider may have a persistent public provider page.
Review the full provider report. It represents the public activity ISP Tracker currently follows for that provider, not only one visitor’s location.
Refine locally. Use ZIP/postal code or neighborhood/area to find local matches where coverage exists.
Keep the wider view in mind. A filtered local result is one part of the broader provider report.
If the provider is recognized but no local report exists, ISP Tracker knows the provider but does not yet have enough public reliability activity for that area. If it is not recognized, there may not be enough public monitoring data yet.
Internet Disruption Watch
This is the “what we are watching” area. It summarizes recent provider-side activity and related patterns that may point to a larger problem.
  • Watching means ISP Tracker is following evidence for a developing or continuing pattern.
  • Recent activity slowed means the related activity has eased; it does not erase earlier observations.
  • Items are ordered by the newest activity supplied by the monitoring backend.
  • The public summary intentionally leaves out internal routing evidence and technical details.
Disruption Watch does not claim that an entire provider is down. It shows measured activity worth following.
Website Reachability Board
The board shows current website reachability evidence from reporting locations. Open a tile to see recent local history, including the area, time, provider when known, and what the location observed.
Green
Currently reachable from reporting locations.
Amber
One monitored area reports trouble reaching it.
Orange
Multiple monitored areas report trouble reaching it.
Red
Multiple separated areas currently cannot reach it.
Gray
Not enough recent data.
Important: Amber, orange, or red does not automatically mean the website is down for everyone. The cause may be a local ISP, regional routing, DNS, the website, or another network path.
Report an Internet Problem
You can report what you are seeing without creating a WordPress account. Reports help ISP Tracker compare visitor experience with monitored evidence.
Choose the issue type, enter the provider and location information you are comfortable sharing, and optionally include an affected website or public comment. “Neighborhood or area” can mean a subdivision, district, village, borough, town area, or another useful local label.
Reports are reviewed before public use. Submission does not promise immediate publication, but it can improve public visibility and reporting accuracy in your area.
Improve coverage with an ISP Tracker agent
An agent is ISP Tracker monitoring software or hardware running at a real location. It gives you useful information about your own connection while adding another public-safe point of view for your provider and area.
Better answers for you
Build connection history and get more context when the problem may be beyond your equipment.
Better answers nearby
Several participating homes, businesses, remote workers, or IT-managed sites make neighborhood and provider patterns easier to recognize.
Agents can run on supported Windows, Linux, ARM/hardware devices, servers, and dedicated ISP Tracker hardware. A phone is not the continuous monitoring agent. Mobile visitors can create an account now and install later from a supported computer or hardware device.
Free monitoring remains available. New users can receive 90 days of full-feature Extended Service with promotion code 90d-july-5-2026. Afterward, continue with the free service or choose Extended Service. There is no obligation.
Privacy, public information, and time zones
What public pages may show
Public-safe provider names, broad location labels, ZIP/postal areas where appropriate, plain-English status, recent history, and broad evidence summaries.
What public pages do not show
Raw agent IDs, private IPs or hops, internal database details, secrets, LAN addresses, raw routing evidence, or technical identifiers that could expose private monitoring details.
Wording is intentionally cautious in sparsely monitored areas so one participant is not made identifiable.
Provider-wide reports use relative time where possible because one provider can span several time zones. Area-specific details use the affected area’s local time when supplied. UTC is primarily an internal or fallback value.
