Enterprise & Organizations - Pricing Plans
Monitoring customized for your company.
Mix Hardware and Software Agents for flexibility in different environments. Next, choose a monthly licensing package based on the number of locations you need to monitor. ISPTracker.com delivers powerful, affordable tools to track, diagnose, and stay ahead of internet connection issues. Benefit from volume pricing and centralized deployment options for large-scale operations.
Software Agent
Software agents are lightweight programs you install on an existing Windows or Linux machine.
Cost-Effective Setup
Quick Installation
No Additional Hardware
Computer running 24/7
Ideal When:
- You already have a computer running 24/7.
- You want a low-cost monitoring solution.
- You prefer no extra hardware added to your network.
Advantages:
- No additional hardware to purchase.
- Quick setup in minutes.
- Affordable enhanced service plans available.
Considerations:
- Monitoring stops if the computer is powered off or rebooted.
- Depends on the reliability of your existing system.
Hardware Agent
Hardware agents are small, stand-alone devices dedicated entirely to monitoring your internet connection 24/7, even when other equipment is offline.
Independent Operation
High Reliability
Continuous Monitoring
Plug-and-Forget Solution
Ideal When:
- You want reliable monitoring independent of any computer.
- You need continuous monitoring without interruptions.
- You prefer a plug-and-forget solution with minimal management.
Advantages:
- Independent from your computers.
- Highly reliable, self-updating, and always active.
- Perfect for remote, unmanned locations.
Get Started:
1. You can create software agents just by clicking the download button and installing the software on the computers you want to monitor.
2. If you would like to purchase hardware agents, choose from our 100Mbps or 2.5Gbps agents (or a mix of both) and follow the checkout instructions to purchase them. We will configure and ship them to your address.
3. To access the Enterprise monitoring features, you must purchase a monthly license per hardware or software agent. See options below or call 1-480-900-8025 if you have questions.
Hardware Agent Pricing
100Mbps Hardware Agent
Always On Monitoring Device- Optional 100Mbps hardware agent
- Monitor wired, WiFi, LTE/4G/5G services
- Self-updating, on 24/7, at less than 1 amp
- Built in DNS server for privacy
- Optionally connect a webcam
- Optional environment sensor (select models)
- Optional secure, encrypted, remote LAN access
- Learn more about our hardware agents
2.5Gbps Hardware Agent
Always On Monitoring Device- Optional 2.5Gbps hardware agent
- Monitor wired networks
- Self-updating, monitors 24/7
Agent License Pricing
License pricing, discounts, and support
Our prices include full support. No tokens, extra charges, complicated contracts, no unknowns,
Our monthly licensing system is designed to be flexible and easy to manage:
- One License per Agent: A license means an agent, AKA location, being actively monitored. 10 minimum/month.
- Install as needed: You can install as many agents as you require.
- Full Dashboard Control: From the dashboard, you can choose which of your agents are licensed at any time. For instance, if you have 30 agents installed, and have 15 licenses, you can assign up to 15 licenses to any installed agents.
- Change as needed, apply licenses only to agents you need reports from. Unlicensed agents have data collection temporarily paused.
- Initial billing is starting count selected (1-10, or 41-50 for example) and +/- are automatically calculated at the end of the next month.
Our goal is to ensure you have the exact amount of coverage you need, with the flexibility to adapt as your organization changes.
For very large installations, we can work with you on pricing.
Click the button below to create your account which will give you the option to purchase the initial 10 pack of monthly licenses. You can add more licenses after your Organization account is set up.
